What should be considered about the environment before flying the DJI Mavic 4 Pro?
Publicado: Junio 12, 2025, 1:32 pm
What should be considered about the environment before flying the DJI Mavic 4 Pro: Before each flight, it is essential to assess the physical and electromagnetic environment where the DJI Mavic 4 Pro will be operated. The manual emphasizes the importance of avoiding areas with high electromagnetic interference, such as industrial zones, power lines, telecommunications stations, or dense urban areas. These environments can disrupt the GNSS signal or interfere with transmission between the drone and remote controller, causing loss of control or navigation errors.
Furthermore, it is recommended to avoid reflective surfaces such as car roofs or bodies of water for takeoff, as they can confuse the vision and infrared sensors. Takeoff should be done from flat, non-moving surfaces with good lighting if vision support is desired. In low-light or nighttime conditions, the vision system is disabled and sole reliance on GNSS must be exercised, requiring even greater caution.
In natural environments, it is essential to stay away from flocks of birds, as they can react aggressively to the drone. Extreme weather conditions, such as rain, storms, thick fog, or temperatures outside the operating range of -10°C to 40°C, should also be avoided. Flying in these environments can compromise both the sensors and the battery, significantly reducing safety and autonomy.
Finally, it is vital to check the weather forecast before flight, especially wind speed, which can vary significantly at different altitudes. Although the Mavic 4 Pro is designed to withstand moderate winds, strong gusts can cause destabilization or make it difficult to return to the home point. Evaluating the environment before flying is an essential practice that improves safety and the user's flight experience.
