What benefits does the DJI Mavic 4 Pro's Intelligent Battery Management System offer?
What benefits does the DJI Mavic 4 Pro's Intelligent Battery Management System offer: The DJI Mavic 4 Pro's Intelligent Battery Management System is an advanced technology designed to maximize the safety, efficiency, and durability of the battery throughout its entire lifecycle. This system continuously monitors key parameters such as the voltage of each cell, charge and discharge current, internal temperature, and the overall health of the battery pack. Thanks to this real-time monitoring, the drone can make autonomous decisions about when to alert the pilot, reduce power, or activate an emergency return if it detects a critical anomaly.
One of the most notable benefits is the self-discharge feature when the battery remains stored for several days without use. This gradual process reduces the charge level to a safe value for long-term storage, helping to prevent the swelling and chemical degradation that often affect lithium-polymer batteries when idle. So, even if the user forgets to manually discharge the battery, the system does so automatically, maintaining its long-term health.
The system also includes overheating and low-temperature protection. For example, if the battery is too hot after an intense flight, charging will not begin until the temperature drops to safe levels. Similarly, if the battery drops below a minimum temperature before beginning a flight, the system can limit power or issue a warning to prevent performance issues or damage. This is especially useful for flights in extreme climates, where operational risks increase significantly.
Additionally, the Intelligent Management System allows the user to view the complete battery status through the DJI Fly app, including the number of cycles completed, the estimated lifespan, and any error history. This transparency helps users make informed decisions about when to replace a battery or how to improve its maintenance. Together, these features make the Intelligent Management System a key tool for maximizing the performance and safety of the DJI Mavic 4 Pro on every mission.
