What wind resistance does the DJI Mavic 4 Pro have, and how does it affect its flight performance?
Publicado: Mayo 21, 2025, 8:39 am
What wind resistance does the DJI Mavic 4 Pro have, and how does it affect its flight performance: The DJI Mavic 4 Pro offers wind resistance of up to 12 m/s, which is roughly equivalent to winds of level 6 on the Beaufort scale. This capability positions it as a high-performance drone, ideal for outdoor missions where weather conditions can change suddenly. This resistance allows the Mavic 4 Pro to remain stable and maintain its course in moderate to strong winds, reducing the risk of unforeseen deviations during automatic flights or cinematic recordings.
In practical terms, this feature is especially useful for flights in coastal, mountainous, or open countryside areas, where wind gusts are more common. For example, if you are capturing a panoramic video on a mountaintop, the drone's wind resistance ensures that the shot is not interrupted by sudden movements or jolts. The stability provided by the intelligent flight system and its sensors also allows for precise flights in scenarios where other, lighter drones might fail.
However, it's important to understand that although the drone can tolerate certain wind speeds, this doesn't mean it should be flown in extreme conditions regardless of the battery level or distance to the takeoff point. A constant headwind can result in increased power consumption when returning to the home point, which could significantly reduce flight endurance. For this reason, it's always advisable to plan flights with additional safety margins when constant or gusty wind conditions are detected.
Furthermore, the performance of the Mavic 4 Pro's stabilization systems, such as its three-axis gimbal and multi-sensor navigation system, helps compensate for small oscillations generated by the wind. This not only improves flight safety but also ensures that the captured images maintain professional quality, without distortions caused by unintentional movements of the drone during flight.
