What type of internal and external memory does the DJI Mavic 4 Pro support?
Publicado: Mayo 21, 2025, 8:34 am
What type of internal and external memory does the DJI Mavic 4 Pro support: The DJI Mavic 4 Pro has 12GB of internal memory, which is useful for emergency recordings or when you forget your microSD card. This internal memory can store a limited amount of content, such as JPEG or RAW photos and short 4K videos, although its capacity is not sufficient for extended recording sessions. Therefore, it is recommended to use it only as a temporary backup and not as your primary storage solution.
For an optimal experience, the drone supports high-speed microSD cards with capacities up to 1TB. DJI recommends using cards with a minimum write speed of V30 or higher, such as UHS-I or UHS-II, especially if recording in 4K resolutions or with codecs like Apple ProRes, which generate large file sizes. Using a card with an inadequate speed may result in recording errors, loss of quality, or interruptions in file saving.
One of the advantages of the DJI Mavic 4 Pro is that it allows users to switch between internal memory and an SD card from the DJI Fly app, allowing them to decide where to store their files before starting a flight. This feature is useful in environments where manually switching cards is impractical or when flexibility is required to transfer files quickly upon completion of recording. Additionally, the system notifies the user if a microSD card is not inserted or if it is full, preventing a recording from starting without available capacity.
It is recommended to format the microSD card on the drone itself before use to ensure full file system compatibility and avoid potential conflicts. Additionally, keeping multiple memory cards ready is a good practice for photographers or videographers who need to continue recording without interruptions. Efficient storage management is essential to take full advantage of the DJI Mavic 4 Pro's recording capabilities during long or demanding sessions.
