What type of battery does the DJI Mavic 4 Pro use and what is its average flight time?
Publicado: Mayo 19, 2025, 8:56 am
What type of battery does the DJI Mavic 4 Pro use and what is its average flight time: The DJI Mavic 4 Pro is equipped with a high-capacity 4S LiPo intelligent battery, specifically designed to optimize the drone's energy efficiency and extend its time in the air. This battery has a capacity of 5,100 mAh, allowing it to offer a flight time of up to 45 minutes under optimal conditions, according to factory tests. This battery life makes it one of the drones with the longest flight duration in its professional category.
Flight time may vary depending on factors such as wind, altitude, payload, and the type of maneuvers performed during the mission. For example, static flights or smooth movements tend to consume less power, while operations involving sharp turns or rapid takeoffs may reduce flight time. However, the energy efficiency of the Mavic 4 Pro's propulsion system is designed to maintain a balance between power and consumption, ensuring reliable performance.
The battery features an intelligent management system that monitors key parameters such as temperature, voltage, and charge cycles. This allows the pilot to have real-time information on the battery's status through the DJI Fly app, helping to prevent deep discharges or overheating. It also features overcharge protection and self-discharge functions to extend its lifespan during storage periods.
Thanks to this long-lasting battery, DJI Mavic 4 Pro users can undertake longer-range missions, capture more content in a single flight, and minimize the number of spare batteries needed. This feature is especially beneficial for aerial photographers, surveyors, documentary filmmakers, and filmmakers who require extended flight time to achieve high-quality results without frequent interruptions to change batteries.
