How much internal storage does the DJI Mavic 4 Pro have, and what types of microSD cards does it support?
How much internal storage does the DJI Mavic 4 Pro have, and what types of microSD cards does it support: The DJI Mavic 4 Pro is equipped with 32GB of internal storage, allowing images and videos to be saved even if the user forgets to insert a microSD card. This space is particularly useful for quick flights, emergency shots, or as a backup in case of external card failure. Additionally, the built-in storage makes it easy to access files via QuickTransfer or directly connecting to a computer, without the need to physically handle external cards in the field.
However, to take full advantage of video recording capabilities in 4K or even higher resolutions, DJI recommends using high-performance microSD cards compatible with the UHS-I or UHS-II standard. Cards must have a minimum write speed of V30, and capacities up to 512GB are supported, which is ideal for extended professional filming sessions. This ensures smooth recording without dropped frames or buffering.
It's important to mention that the drone can automatically switch between internal storage and an external card if the microSD card is not inserted or is full. Recording priorities can also be manually set from the DJI Fly app. Transfer speeds also vary: for faster downloads, you can use a USB 3.0 cable connected directly to the drone, or remove the card and use a card reader.
As a precaution, DJI recommends not removing the microSD card while recording videos or taking photos, as this could corrupt the files or the card itself. It's also vital to keep both the slot and the card's metal contacts clean, and to format it regularly from the drone's own system to ensure compatibility and optimal performance.
