What transmission system does the Mavic 4 Pro use, and what benefits does it offer for long-range flights?
What transmission system does the Mavic 4 Pro use, and what benefits does it offer for long-range flights: The DJI Mavic 4 Pro is equipped with the O4+ transmission system, an advanced technology that significantly improves the range, stability, and quality of the signal between the drone and remote controller. This system allows high-definition video transmission up to a distance of 20 kilometers in ideal conditions, far exceeding the performance of previous generations. This means operators can fly considerable distances without signal loss, ideal for open-field exploration, recording large areas, or hard-to-reach industrial inspections.
The O4+ system not only offers greater range but also a more robust signal in urban environments where electromagnetic interference can be a problem. It uses an automatic frequency-shifting algorithm that detects and selects the cleanest channels in real time, reducing interruptions caused by Wi-Fi networks, cell towers, or nearby electronic devices. This connection stability is vital for flights in densely populated areas or with vertical obstacles such as tall buildings.
Furthermore, O4+ enables 1080p video transmission at 60 fps, providing an extremely smooth and detailed first-person view, essential for performing precise maneuvers or complex framing during flight. This real-time image quality not only enhances the pilot's experience but also helps prevent errors, avoiding collisions and improving the quality of the recorded content. It also facilitates operation in low-visibility conditions, such as light fog or night flights.
Finally, this transmission system also reduces signal latency to almost imperceptible levels, resulting in a more immediate response to pilot commands. This is essential when performing manual flights close to objects or people, where accuracy and reaction time are critical. With O4+, the DJI Mavic 4 Pro sets a new standard in aerial communication, offering a more reliable, clearer, and long-range connection that expands its usability in all types of missions.
