How does GPS signal quality affect DJI Flip accuracy and how can it be improved?
Publicado: Febrero 27, 2025, 8:13 am
How does GPS signal quality affect DJI Flip accuracy and how can it be improved: The GPS signal is critical to DJI Flip, enabling precise navigation, maintaining drone stability, and enabling advanced features such as Return to Home. A weak or unstable signal can cause trajectory deviations or make it difficult to maintain position.
To improve GPS signal quality, the operator should fly in open areas away from tall buildings, communication towers, or metal structures that may cause interference. It is also recommended to wait a few seconds after powering on the drone for it to acquire enough satellites before taking off.
If GPS is unstable, DJI Flip can automatically switch to a vision-assisted flight mode. However, in low-light conditions or over reflective surfaces such as water, these sensors may struggle to maintain stability.
Thanks to its advanced positioning system, DJI Flip dynamically adjusts its use of GPS and optical sensors to maximize accuracy on every flight. Following these recommendations will help reduce navigation errors and improve your operating experience.
