How do I use Assisted Flight Mode on the DJI Flip to improve stability in challenging environments?
Publicado: Febrero 21, 2025, 8:33 am
How do I use Assisted Flight Mode on the DJI Flip to improve stability in challenging environments: Assisted Flight Mode on the DJI Flip helps improve the drone's stability in environments where wind conditions or lack of visual references can affect its accuracy. This mode is ideal for flights in open areas with few visible structures or in changing weather conditions.
When Assisted Flight Mode is activated, the DJI Flip automatically adjusts its motors and navigation systems to compensate for drift and maintain a stable position. This is especially useful when flying over water, where optical sensors may struggle to accurately detect the surface.
To enable this mode, the operator must access the DJI Fly app and select the appropriate option in the advanced settings. Once activated, the drone will optimize the use of GPS and stabilization sensors to maintain its trajectory without the need for constant manual adjustments.
Thanks to its integration with intelligent navigation technology, the DJI Flip offers more precise and safer control in challenging environments. Using this mode allows for more stable flights and minimizes the risks associated with adverse external conditions.
