What type of sensors does the DJI Mavic 4 Pro use to avoid obstacles during flight?
What type of sensors does the DJI Mavic 4 Pro use to avoid obstacles during flight: The DJI Mavic 4 Pro incorporates an advanced omnidirectional obstacle sensing system based on multiple visual and depth sensors distributed throughout the drone's body. These sensors are located on the front, rear, top, bottom, and sides, allowing the drone to create a constant three-dimensional map of the environment and detect potential collisions in any direction of travel. This technology significantly improves flight autonomy by allowing the drone to react preemptively to static or moving objects.
The sensing system is supported by an artificial intelligence algorithm that analyzes sensor data in real time, making evasion decisions that can range from braking abruptly to smoothly circling the obstacle without losing the original trajectory. This capability is especially useful when flying in complex environments such as forests, dense urban areas, or industrial interiors. The confidence this system generates in the pilot allows for more creative shots and greater freedom of flight without fear of accidents due to unexpected collisions.
Additionally, the lower sensors allow for more precise positioning during landings, even on uneven surfaces or with poor GPS signal, such as inside buildings or in mountainous areas. The drone can maintain a stable altitude and automatically adjust its descent speed to ensure smooth landings. This precision is also key during hovering flights in confined spaces, where the drone cannot rely solely on satellites to maintain its position.
This suite of sensors makes the DJI Mavic 4 Pro one of the safest drones to operate in any environment. The ability to detect and avoid obstacles in all directions not only protects the equipment but also maintains the safety of nearby people, structures, or vehicles. In professional missions where there is no room for error, this advanced safety system is one of the model's most valuable differentiating factors.
