What precautions does the DJI Mavic 4 Pro recommend when using TapFly in tight spaces?
What precautions does the DJI Mavic 4 Pro recommend when using TapFly in tight spaces: The DJI Mavic 4 Pro recommends using TapFly in wide, open spaces, as the aircraft will follow the path selected on screen without stopping until the pilot cancels it. Although obstacle detection sensors help avoid collisions, in tight environments the chances of error increase significantly.
It is important to always maintain line of sight with the drone to anticipate potential hazards. Additionally, the operator must be prepared to stop the mode immediately if anything unexpected arises, such as the appearance of people, vehicles, or unexpected objects in the path.
Lighting is also a critical factor, as TapFly relies on visual sensors to maintain stability. In low-light conditions or on reflective surfaces, the system's accuracy may be compromised, increasing the risk in tight spaces.
In conclusion, TapFly is a valuable tool for simplifying trajectories, but it should be used with caution in confined environments, always prioritizing the safety of the drone and its surroundings.
