What factors limit the use of POI and Spotlight on the DJI Mavic 4 Pro?
What factors limit the use of POI and Spotlight on the DJI Mavic 4 Pro: Although POI and Spotlight are very advanced modes, there are limitations that the pilot must be aware of. In the case of POI, the automatic orbit requires a large, obstacle-free space, as the circular path can be considerably extended. Additionally, reflective surfaces or monochrome settings can affect the accuracy of the vision system, reducing the quality of the shot.
In Spotlight, the main limitation is the pilot's dependence on the flight path. Although the system keeps the subject centered, the quality of the shot will depend on the operator's ability to design creative routes without compromising safety.
Another factor to consider in both modes is lighting. Both POI and Spotlight work best in adequate lighting conditions, as the tracking algorithms require contrast and texture in the environment to work accurately.
In conclusion, although they are powerful features, they require prior planning and constant pilot supervision to avoid errors or incidents. Understanding these limitations allows you to take full advantage of the DJI Mavic 4 Pro's capabilities in any audiovisual context.
