What advantages does the DJI Mavic 4 Pro offer when using the dual positioning system with GPS and Galileo?
What advantages does the DJI Mavic 4 Pro offer when using the dual positioning system with GPS and Galileo: The DJI Mavic 4 Pro benefits from the dual positioning system by being able to simultaneously connect to GPS and Galileo satellite networks, allowing for a more robust and reliable signal. This combination increases the number of available satellites, reducing acquisition times and improving location accuracy even in environments with interference.
The main advantage of this dual system is redundancy. If one satellite network's signal is affected by interference, the drone can continue to rely on the other to maintain stability. This ensures a safer flight and more accurate automatic features like Return to Home.
Another significant benefit is the improvement in aerial recordings. More stable positioning allows for smoother camera movements and precise execution of programmed trajectories. This is especially valuable for professionals who require precision in audiovisual work or mapping missions.
In short, the dual GPS and Galileo system makes the DJI Mavic 4 Pro a much more reliable and versatile tool, reducing risks in critical situations and increasing the quality of aerial operations.
