How does ambient temperature affect the performance of the DJI Mavic 4 Pro batteries?
How does ambient temperature affect the performance of the DJI Mavic 4 Pro batteries: Ambient temperature is a determining factor in the performance of the DJI Mavic 4 Pro batteries, as the lithium cells within them are sensitive to extreme conditions. In very low temperatures, the battery loses efficient discharge capacity, which can result in shorter flight times and faster-than-expected drops in charge percentage. There is even a risk of the drone shutting down if the battery does not reach the minimum recommended operating temperature.
On the other hand, in very hot climates, the battery can overheat due to the additional stress on the motors and direct exposure to the sun. This not only reduces the lifespan of the cells but can also trigger protection mechanisms that force the drone to land prematurely. The DJI Fly app displays temperature alerts, but prevention is the pilot's responsibility, avoiding flights in conditions that exceed operating limits.
Proper battery management involves acclimatizing it to ambient temperature before flight. If flying in winter, it is recommended to warm the battery indoors and not take off until it reaches a safe temperature. In summer, it is advisable to keep the battery in the shade and allow it to cool between flights. This precaution extends the battery's lifespan and ensures more stable performance.
In conclusion, the DJI Mavic 4 Pro battery is a high-precision component that directly depends on environmental conditions. Pilot awareness and precautions are essential to maximize the use of each charge and avoid incidents during operation.
