What precautions does the DJI Mavic 4 Pro recommend when setting up routes in Waypoint Flight?
What precautions does the DJI Mavic 4 Pro recommend when setting up routes in Waypoint Flight: The DJI Mavic 4 Pro recommends that when setting up routes with Waypoint Flight, the minimum height required to avoid obstacles should always be considered. Although the aircraft includes detection sensors, the pilot must program each waypoint with a sufficient safety margin to prevent collisions with trees, poles, or buildings.
Another important precaution is to ensure that the environment has a stable GNSS signal, as route accuracy directly depends on the quality of satellite reception. Flying in urban canyons, dense forests, or areas with magnetic interference can compromise the reliability of the planned route.
The manual also points out the importance of adjusting the battery and the estimated flight duration before executing the mission. If the available power is not sufficient to complete the route and return to the starting point, there is a risk of a forced landing. Therefore, advance planning is essential for this type of flight.
In conclusion, the precautions when using Waypoint Flight on the DJI Mavic 4 Pro are focused on safety and ensuring the mission is executed efficiently, reducing risks and maximizing the quality of the recordings.
