How does the DJI Mavic 4 Pro behave in ATTI mode when it loses GPS signal?
How does the DJI Mavic 4 Pro behave in ATTI mode when it loses GPS signal: When the DJI Mavic 4 Pro enters ATTI mode due to a loss of GPS signal, it maintains altitude using its barometer, but cannot maintain a stable horizontal position. This means the aircraft can drift slowly in any direction driven by wind or air currents, forcing the pilot to make constant control corrections to maintain the desired location.
In this mode, the drone does not have navigation assistance nor can it execute programmed trajectories or intelligent flights. All maneuvers depend solely on the operator's skill, which increases the level of difficulty. Therefore, it is a state that requires experience and constant attention to avoid collisions or loss of control.
The visual and infrared sensor system partially helps stabilize flight at low altitudes, but its range is limited and depends on terrain and lighting conditions. This means that, although they provide some assistance, they do not replace the accuracy of GPS during prolonged or high-altitude flights.
The pilot must be prepared to assume manual control at any time, and if the signal is not recovered, it is best to guide the drone to a safe landing location. Understanding how ATTI mode works is essential for operating safely in the event of a loss of GPS signal.
