What consequences can an incorrect calibration of the DJI Air 3S sensors have?
Fórum DJI AIR 3S Drone Everything you need to know about
What consequences can an incorrect calibration of the DJI Air 3S sensors have: Incorrect calibration of the DJI Air 3S sensors can significantly affect flight stability, safety, and accuracy, leading to navigation errors, false positives or negatives in obstacle detection, and even unpredictable behavior when using automatic functions. Calibration is the process by which the system adjusts its internal parameters based on the environment and the physical state of the components. Therefore, poor calibration can lead to an inaccurate perception of the space around the drone.
For example, if the compass is not calibrated correctly, the drone may experience orientation deviations, misinterpret its direction, and react incorrectly to pilot commands. This results in unintentional turns, loss of precision during automatic returns, or erratic trajectories during Waypoint flights. Similarly, incorrect calibration of the Downward Vision System can lead to failed landings, loss of stability during flights without GPS, or progressive drift when attempting to maintain a fixed position.
The consequences also affect the obstacle detection system. If the sensors are not properly calibrated, they can overestimate or underestimate actual distances, leading to inappropriate reactions, such as unnecessary braking, poorly executed evasions, or collisions due to lack of response. This represents a risk to both the integrity of the equipment and the operating environment, especially in technical missions or flights in urban areas with delicate structures or people nearby.
Therefore, it is essential to perform calibration following the manufacturer's specific recommendations, in safe environments with optimal lighting and magnetic stability conditions. Furthermore, it is recommended to periodically check the calibration status from the DJI Fly app and repeat the procedure every time the drone is transported to a new geographic region, after a collision, or if unusual behavior is detected. Proper calibration ensures that the DJI Air 3S operates with maximum precision and that all its intelligent functions and sensors work in harmony.
Volver a “Everything you need to know about the DJI AIR 3S Drone fórum”
